Hi all,
Thought I better do a build log as I haven't seen to manyfor the Lian Li PC-Q08B. I decided to do a M-ITX build and get rid of the Coolmaster 932 and have my PCon the desk. I have a had ITX PC in the past but I let the parents have it.
First I sold most my old PC parts.
Then I bought the new parts.
When I first put the PC together I had problems getting the ram running in Dual channel but a bios reset sorted that. I also had to buy the Antec Cooler as there is only room for a 10cm cooler in the case and most low profile coolers wouldn't fit the GA-H55N-USB3 (I did try using the stock cooler but temps were very bad).
![](http://img263.imageshack.us/img263/103/dsc01910small.th.jpg)
![](http://img140.imageshack.us/img140/7589/dsc01912small.th.jpg)
![](http://img685.imageshack.us/img685/659/dsc01914small.th.jpg)
I had to trim the H20 mounting plate so it didn't touch the resistors or whatever they are on the back of the motherboard. I had read about needing to do this on the GA-H55N-USB3 board with the Corsair H50 so I was expecting the same. I just used a pair of wire cutters and it didn't cause a problem really.
![](http://img576.imageshack.us/img576/4434/dsc01917small.th.jpg)
Cooler fitted with the slim fan to allow space for the power supply.
![](http://img200.imageshack.us/img200/4598/dsc01923small.th.jpg)
Everything else fitted in the case. It looks messy but I can see in the case and there is plenty of room in and around the CPU and memory. If I had a modular PSU things would be tidier.
I haven't tried overclocking yet but I hoping I can at least get 3.4/3.6Ghz although im not sure how good the ram will be. Any OCUK member with experience clocking i7860 with this board? My idle temps with this cooler are around 24c-29c.
Finished Pictures
![](http://img546.imageshack.us/img546/6260/dsc02204small.th.jpg)
![](http://img135.imageshack.us/img135/5351/dsc02205small.th.jpg)
- E5200 @ 3.7GHz
- 4Gb
- GT260
- GA-965P-DS3
- HAF932
- i7 860 (mm) (£120)
- Lian Li PC-Q08B (£90)
- Kept my GT260
- Corsair Value 2GB DDR3 PC3-10666C9 1333MHz Low-Voltage & Corsair Value 4GB (Already had it)
- Gigabyte GA-H55N-USB3 (Auction site £65)
- Antec Kúhler H2O 620 (OCUK £49)
- Kaze Slim 120x120x12mm fan (So I could fit the Antec H20)
- 2 old 500GB and 120GB hard disks
Finished Pictures
