- 12 Jan 2006
Ok i finished overclocking my duron 750 and have it running at 950Mhz
I have upgraded the ram to 768Mb (much as it goes, and loostened the timings a bit as some of it was slower stuff
Specs for those that are interested:
Processor: Duron 750 - running at 950Mhz
CPU Heatsink: Modded Zalman AeroFlower
RAM: Assorted bits of SD ram
out of various older pc's so no point naming them all PC100 being the slowest so all the settings are based on that
Motherboard: Abit KT7A
Gfx Card: Gainward Geforce 4 MX 440 128mb
Soundcard: Soundblaster live 1024
So onwards and upwards as they say ^^
I want to now make this into a media pc to plug up to the TV.
But heres the catch, i want to do the following things:
-Record Programs from the TV to the PC
-Record Programs on the VCR
-Run movies from other pc's on the network
I have done a bit of research and it turns out i need a TV Tuner to recieve the signal on the pc, and i need a gfx card to output that signal to the TV.
So can recommend a resonable priced tv tuner card that doesnt require a particularly powerful pc, if possible be HD TV compatible too
Thanks in advance
out of various older pc's so no point naming them all PC100 being the slowest so all the settings are based on thatMotherboard: Abit KT7A
Thanks in advance
