My local church (from my bedroom!)
12 Jun 2003
Either Tonbridge or Biggin Hill
Hi all,
Thought I'd share this with you, shot from my bedroom window approx. 1/4 mile away.
F/5.6, 4.5s, ISO 800, tripod (EXIF is embedded)
MarcLister said:
Nice pic but I don't see any EXIF info.
Depends where you look I suppose. Right-click, save the image to your desktop. Now right-click on the icon there, select Properties -> Summary -> Advanced.... et voila :)
Right I see it now but why does it now show in Firefox? I have the FxIF extension installed.
Ooh, didn't know it was even possible to view in Firefox! Sorry, not sure why it doesn't display....
/me goes off in search of FxIF.... :)
If you are going to do a long exsposure then use a lower ISO and 'Long Exsposure Noise Reduction' turned on. Try shooting that again (in RAW, so you can change the temperature of the building too) using ISO 100/200 for 8 ish seconds at f5.6 (obviously estimated). Might get a better result.
Just my thoughts,...
King.
King.
OK, I'll give that a go tomorrow night - I've put the camera away for now. Will post the results. Thanks for the tip :)
