hi
yesterday me and my carer (P.A) took my 6990 to my local computer shop has I know the guys there, i asked them to open it and clean it out. but first I said are you sure you know what your doing with graphic card, he said yes I've done this many times, I said ok but make sure you don't break it. so I watched him opening it which took a good 30min all that was ok, then him and another guy started cleaning it out, he removed the heat sink, fan to clean them, removed pads, thermal compound, that took a good 45min that went ok. now this is where the stupid part is. when it was time to put it back together he had to replace the pads so he did that and put some thermal compound on both GPU's, (but I thought to my self the pads look to thick) so I said are you sure the pads are ok for this, he said yeah. so I said ok. he put it all back together, when he finished I thought to myself it doesn't look right, but I went with it. from start to finish it took 1hour 50min~ anyway so I bought both guys a mcdonalds so say thanks for doing it. when I got home I got my mum to put it back in my pc, then turned it on and after about 5 seconds the graphic card fan span up to like 100% and I said turn it off has something is wrong. so I got my mum to remove the graphic card and open it, and it opened so easy due to the heat sink wasn't even touching the GPU's due to the pads being to thick. so I told her to remove the pads then put a little ocz freeze thermal compound on the ram, bridge, vrm's chips then close it. I told her to put it back in my pc, turned it on, fan is ok, and so far it seems ok.
so the two guys got a mcdonalds (2 happy meals) out of me for nearly breaking my graphic card.
if I wasn't disabled I would have did it myself, has I knew how to do it.
