- 4 Sep 2009
All arrived on Tuesday, thought I'd finally get around to posting some build images.
Enjoy:
Specs:
I didn't want to risk wasting my money on a cooler that wouldn't fit. I've yet had time to test how the case performs under load. I'm seeing temperatures vary from 46 to about 50 degrees idle. At the moment just doing a massive yum update it's at 48 degrees.
Was a very fiddly build but I expected that. My only two issues were that during the journey home (I built it during my lunch hour at work), one of the SATA cables came loose and jammed the CPU fan. BIOS alerted me that the CPU was then running at 220 Degrees C. I don't appear to have done any damage, but as I say I've yet to run tests or dared to take the heatsink off. Aside from that the PSU's fan doesn't appear to be working unless it is thermally activated.
Love the box, I wish the hardware was ESXi supported, however for now I'll have to settle with dual booting windows server 08 MSDNAA and fedora 11. I'll probably virtualize a couple of things from fedora for my University's LAN party
All in all, a nice tiny powerful box. Just what I wanted!
Enjoy:
Specs:
- IN-WIN BM639 Case with 120W PSU
- Q8400
- Stock cooler
- 4Gb OCZ RAM
- 1TB WD Green HDD
- Zotac 9300 Mini-ITX motherboard
- Samsung slimline DVD drive
- Extra NIC
. Would depend, of course, on temperatures.
I had intended to keep it running 24/7 but it just runs too loud for me to sleep in the same room as it... I might have to move it into a cupboard if I can't sort the problem out
