My Mini-itx build.
13 Jan 2004
Bucks
Here's some photos of my latest build. Enjoy
(Specs: Lian-Li pc q07, Zotac 9300-itx, C2D E6600, 2GB DDR2 800
W/C: Laing DDC pump with XSPC top, XSPC Delta V3 waterblock, XSPC delta chipset block)
looks nice... Loving the little cable (Maybe power switch) that looks like its an electrical Arc).. Its a really pity that the rad couldnt have been mounted slightly higher to accomodate a gfx card tho..
Yeah it's a pico psu, plugs straight into the power socket on the mobo and has an external power brick. The rad is touching the top of the case right now so a GFX card was not really an option, the onboard GFX is good enough for what this is being used for, plus its drawing 130 watts at present and the psu is only 150 watts. I don't think they make a higher rated picopsu which is a shame...
Even without it its still pretty incredible btw have u though about removing the fans completely. Just as it is a mini-itx might just be able to work with just the rad might be worth the extra heat (passive systems rule :D).
ive tested withought the fans, after a short while the system becomes unstable, it's perfect with one fan, but I like the symmetry.
