- 27 Dec 2006
- Northampton
The tools.
Offical Ati Component adapter.
Dips on the adapter.
Panasonic 32" TubeTV (Excuse the Girls Aloud DVD
And the Component Cables.
Basically I need your help in helping me setup my computer to dispay what I'm seeing on my Desll FPW2006 onto my TV and it connects through the ATI component adapter using the component cables and into the back of the TV.
When I try and set up the TV, all I can see is fuzzyness like the picture if the Mhz is too high or the resolution is too much. The TV displays perfectly when I reboot the computer, i see all the spash screen and bios messages and etc but once it enters windows it goes fuzzy again.
I think its down to finding the perfect resolution and the correct fequency my tv runs at. I've tried forcing it to go from 640 x 320, 800 x 600 and 1080 x 768 and at different freqency. No change.
Its only going to display 480i which i know is the highest my tv goes at.
Any advice would appreciate. Thanks.
