My my cpu has just started overheating
27 Jul 2005
The Orion Spur
The cpu in my secoundry system for no apparent reason has just started overheating, I have'nt changed anything at all, checked the cpu fan speed etc and is fine, the system just kicked my mate off of farcry with a cpu temp of around 75-80 and even taking off the side of the case the temp was hovering around 60-65 idle :( , my secoundry system specs are as follows,
My first instincts was it may be the psu, could this cause my cpu to overheat ?
P4 3.06 northwood
intel m/b 850E
1 gig rambus 1066
550W QTEC PSU
thank for any help.
Checked theres no dust clogged up? Take a look in bios and see the temps in there, could be a software. Also try re-seating the heatsink.. could be a matter of the thermal compound drying up
edit: If you see my other thread in GD, you might think about chaning your PSU ;)
:p I had similar problems, howwver over time, honestly got to 113 Degrees C!!
Not F but C!!!
I opened up the case, which I never dusted in 2 years, and It was immensly clogged up! (Heatsink)
I learnt my lesson - DUST DUST DUST :o
lowrider007 said:
afraid it's not dust, I keep my system air dusted on a regular basis :(
as i said, have you checked the heatsink? It might not have good contact, or the thermal compound could have evaportated :)
