My New 4400+ Going Good
7 Sep 2005
Just got my new 4400 x2 in my system, I have another but it isnt a good clocker.In fact its poor,Ive had it since last Octoberish. This one Looks to be a good one
Stepping: CCBWE 0547UPMW
My old one wouldnt make 2.5Ghz, It ran @ 2.4 with 1.475V .No less.
However this one is now at stock Volts running @ 2640Mhz. I am just priming now, still going strong after a few hours. I know its nothing yet but lets see what happens overnight.
After i have found out my max Cpu speed i will sort out my ram again to match either low/high HTT
my.php
[/URL][/IMG]
Just a little CPu-Z screenie for now.
Justin
Nice chips you got there! smids, you're using phase right? I'm only @ 2.5 on 1.4v atm, yet to 24hr prime it but has lasted 6hrs so should be ok. Gonna try to hit 2.6/7 over the weekend, only forseeable issue is the lack of voltage from this mobo.
my stepping is CCBWE 0532UPMW
btw smids, the geil one you sent is actually godlike and as you say definately needs active cooling :eek: :D
Not phase - see sig, that's watercooled :) - I knew I should have used a lighter blue :rolleyes:
Glad the GeIL worked out ok. It was amazing stuff for me but I just needed more else I would have kept it.
Your stepping it one of the popular retail ones I've seen. Mixed results from those, varying from amazing to average. Hopefully you'll get dual 2.6ghz FX-60 though :).
my.php
[/URL][/IMG]
Justin
Good Good stuff. I got my 4400X2 to that I think on 1.35/ 1.40 volts.
They seem to hit a brick wall at 2.64 and you have to just pump in the volts to get them higher. Iv had to stop because the PWmic chip was overheating because of the high current.
