My new monitor "24"
Caporegime
8 Sep 2006
On Ocuk
http://lcd24-7.info/Monitor/Samsung/SyncMaster-T240/Default.aspx
high dynamic contrast ratio of 20,000:1
Hdmi , USB , VGA , DVI
1920x1200
Wide viewing angle (160 degrees)
Got it for £200
The only negative i can find for this monitor is it has annoying back lighting at the top and bottom of the monitor in dark movies, other than that its :) :) :D
how did you get it for 200?
got mine from OCuk b-grade for £230, but having to deal with Samsung because the colour blue isn't displaying correctly, display a gradient from black to blue and i can see some variants of blue in the darker area is displayed bright blue.
and i thought i got a bargain if Samsung fixes this issue (they are picking it up next week)
For the questions about the price it was " on display " and the last one at pc.w.... thats all im saying ;)
DireEmblem nope
I had one for £250 last week too. I seem to be having trouble funding the right height to use it tho, as now it's a larger screen than I used to have the colour / brightness changes from top to bottom. I suppose thats the problem with this sort of panel tho.
Apart from that it's great. Looks good sat next to my, also new last week, 37" 6 series sammy tv which it matches :D
Nick
If you're sitting directly infront of it, at the correct height, that shouldn't be a problem.
