My new Pc build please need some advice
29 Aug 2024
Germany
1
WD_BLACK SN850X NVMe SSD 2TB Internal SSD​
2 Gigabyte B650 Gaming X AX V2 Motherboard
3 AMD Ryzen 7 7800X3D Processor
4 MSI MAG A850GL PCIE5 Power Supply, 850W, 80 Plus Gold, Fully Modular
5 Crucial Pro DDR5 RAM 32GB Kit (2x16GB) 6000MHz CL36, Overclocking Gaming,
6
Gigabyte Radeon RX 7800 XT Gaming OC 16GB Graphics Card -
7 SMART TECH 32 Zoll Gaming Monitor 240hz Curved, USB-C 65W, 1500R, Mit Zwei Lautsprechern, 1ms, FHD, FreeSync,
8 ARCTIC Liquid Freezer III 360 A-RGB - Water Cooling PC, AIO CPU Water Cooler, Intel & AMD,
I'm on my phone so please Forgive my writing
I Would like to know does everything match up ?
Or did I do it wrong?
Thank you
Welcome to the forums.
Looks ok for the most part.
I prefer MSI, but think you should be ok with the Gigabyte.
Screen is only 1080p. I would get 1440p if you want a 32" screen.
What case have you got? The radiator is massive and may not fit.
I haven't decided yet on Case any recommendations?
Also is my CPU ok with this motherboard?
Thank you
TITAN ARMY 32 Inch Curved Gaming Monitor, 2560 x 1440 240Hz 2K Monitor, 1ms, Adaptive Sync, 1500R, 99% sRGB, HDR400, 75 x 75 VESA, Low Blue Light, HDMI 2.1, DisplayPort 1.4, C32C1S
Is this a good one? I love 32 I don't want to go back to 27
Thank you
I have a Lian li lancool 216 with a Liquid freezer III 360mm and it fits perfect.
Motherboard and CPU will be fine.
I don't know much about monitors, but it does look ok (hopefully someone else will be along to advise better).
I would remove the link though as you are not allowed to link to competitor sites.
Forum rules.
https://forums.overclockers.co.uk/help/boardrules/
I removed the link sorry for that
I appreciate your help
In your first post you mentioned MSI
Are you talking about this
MSI X670E Gaming Plus WiFi Motherboard, ATX - Supports AMD Ryzen 7000 Processors, AM5-14 Duet Rail 80A SPS, DDR5 7800 MHz/OC, PCIe 5.0 x16, M.2 Gen5, 2.5G LAN, Wi-Fi 6E​
Was actually meaning the brand as that is what i am using now and have had no problems what so ever.
That board does look good and price is not unreasonable at £225, but if you are on a budget a B650 will do the job (pcie4 an gen4 m.2 though)
My basket at OcUK:
Total: £183.98 (includes delivery: £3.99)​
I agree with you
I can use more advice like this
Thanks
No probs.
Don't think there is anything wrong with other brands but usually only comment on ones i know about.
Gigabyte for example, i have used them before but way before UEFI was a thing. Was a good board though.
I have used MSI, Asus and Asrock and all have been great.
Have you ordered anything yet?
No probs.
Getting there
I have always been with Asus
This time I would like to try something different
Always liked ASRock and people push me away from them I don't know why
So almost there
Need help with these mo monitors
ASUS TUF Gaming VG34VQEL1A - 34 Inch UWQHD Curved Monitor - 100 Hz, 1ms MPRT, FreeSync, HDR 10 - VA Panel, 21:9, 3440x1440, DisplayPort, HDMI, USB, Ergonomic, Black​
MSI 34" 180 Hz VA UWQHD Gaming Monitor 3440x1440 (UWQHD) MAG345CQR
ERAZER Spectator X50 (MD 21732) 80 cm (32 Inch) OLED QHD Gaming Monitor (165Hz, HDR10, Adaptive Sync, 2X HDMI, DisplayPort, 16:9, Integrated Speakers)​
Witch one?
Thanks
Ok I need help with this
Why does it say 4.4 CPU speed
But unlocked 5.6 ?
So at what speed will my new Pc be?
Thank you
Ok I can't upload picture
Top Highlights
Brand
AMD
CPU Manufacturer
AMD
CPU Model
Ryzen 9
CPU Speed
@. 4.4 GHz.
CPU Socket
Socket AM5
Platform
Windows 11
  • The world's best gaming desktop processor that can deliver ultra-fast 100+ FPS performance in the world's most popular games
  • 12 Cores and 24 processing threads, based on AMD "Zen 5" architecture
  • @. 5.6 GHz Max Boost, unlocked for overclocking, 76 MB cache, DDR5-5600 support
  • For the state-of-the-art Socket AM5 platform, can support PCIe 5.0 on select motherboards
  • Cooler not included
That's the Ryzen 9900x.
4.4ghz is the base clock.
5.6ghz is the boost clock so basically the chip will try and hit this target if the temperatures and power targets allow.
So...minimum 4.4ghz up to 5.6ghz depending on workload, power and temps.
Need help please
This ////
ARCTIC Liquid Freezer III 240 A-RGB - CPU AIO Water Cooler, Water Cooling PC, Intel & AMD, Efficient PWM-Controlled Pump, Fan: 200–2000 RPM, LGA1851 and LGA1700 Contact Frame - Black
Or this///
ARCTIC Freezer 4U-M for AMD: SP6, sTR5, SP3, TR4, sTRX4, SWRX8 and Intel: LGA4189, LGA 4677-4U & UP, Server CPU Cooler, 2 x 120 mm Fans, 400–2300 RPM, Rack Cooling Fan, Server Fan, Rack Fans​
For My Ryzen 990x
Or any recommendations
Thank you
