My New PC for work and games
It is really cool! One of the best things about it is that many internal structures can be removed for better ventillation.
In fact, a gaming PC needs not to be as big as ATX form factor. Whilst this case is one of the best for a small build, the Asus P8Z77-I Deluxe is the best mix for it. It comes with Bluetooth and WiFi! It is pretty convenient specially I have my Samsung Note II always needs to be synced with photos and all those.
In my future upgrade, I am going to get a higher GFX and add one more fan to it.
BTW, the front fan is not connected to any header on the motherboard because it provides only 1 hearder for chasis fan. What should I do to get the front fan going?
Thanks! But I also heard that some folks connect it directly to one of the PSU cable, is that possible at all? Would that burn the fan's motor?
Also there is an installation issue with the P8Z77-I Deluxe motherboard. The graphics card has a 'foot' that blocks the internal audio connector stemmed from the Prodigy front panel, so I can't connect it leaving the front panel audio socket useless. What are the workaround. I notice that there is an audio cable comes with teh Asus motherboard, I don't know what it is for. Any clue?
If you connect it directly to the PSU, you'll have no control of the speed so expect to have some noise :D
better to split it on the board, so you control the speed of both :)
