My new simple PC build - or project CTRL-R
14 Nov 2002
Just my humble effort, a simple, common build (not like the many works of art here) so no log just some pics and spec. CTRL-R due to the nature of finding the graphics and CPU :p
Without the panels on:
And complete:
Msi MAG X570 Tomahawk mobo
Ryzen 5800x CPU
MSI Gaming X Trio RTX 3080
Crucial Ballistix 32gb 3600mhz cl16 Ram
Alphacool Eisbaer 360 AIO, with Tygon tubing, G1/4 compression fittings and Noctua NF-P12 Redux fans
Noctua NF-A9 Chromax at rear exhaust
Aerocool Duo 12 RGB Pro Kit at bottom intake
Lian Li BR-Lite RGB at top exhaust
Phanteks RGB strip
Lian Li O11 Dynamic Case
the only modding I had to do was some minor dremeling to mount the AIO rad the "right" way up, and swapping out the Stock AIO ugly tubing for longer Tygon tubing with G1/4 compression fittings.
First 3 lines of spec
:p
Nice build, looks lovely. Why are the fans on the back rad not RGB?
I meant in terms of the build not components ;)
Rad fans not RGB because A: more important to me to have fans suitable for rad cooling, and B: because I thought there was enough bling as is.
It is my first foray into RGB and I prefer the subtler lighting rather (albeit purple atm) than an explosion in a paint factory effect :p
