- 16 Jun 2010
- Manchester
well its the............... LOL
Lian-Li TYR PC-X500FX chassis
What you guys think ?
I like the look of the new Lian li. One thing I'm worried about is the lack of cable management. The hard drive mounts look like the cables won't be routed through the back behind the motherboard tray, and there are only two small routing holes to the right hand side of the motherboard.
Also there are no top fans on the roof of the case. I love aluminum cases and I'd love a Lian Li but they always seem to miss the boat in terms of air cooling and cable management.
Best case I have used to date for cable management is the Nzxt Phantom, you would struggle to make it untidy![]()
Looks a bit too much like a hot-rod for my taste but to each their own![]()
I cant argue with that I tend to prefer square black cases (like the haf x) but as I said got this on the cheapie, but now that I have it would with out a doubt have paid full price for it, and the shape has kinda grown on me.
I now have 8 fans in this unit (extra one due to push pull and the case temp is around 15 deg.
You don't need n+hundred fans for good cooling... except maybe in open cheese graters totally lacking any kind controlled laminar airflow.want something similar to the R2 with all the fan mounts and a door but higher quality like a lian-li. Unfortunately they don't make anything that seems to be good at cooling and they never have enough fan mounts![]()
There's nothing in your PC which wouldn't be cooled by A71F unless component coolers themselves screw the airflow.
