My next upgrade is...
1 Dec 2005
Stoke on Trent
Changing my CPU from a 3700+ SD to an X2 3800+. Is this a wise choice? Cant really stretch to the 4200+ as ive just spent a fortune on RAM and GFX.
whats wrong with the SD 3700+???
isn't it a bit early to be looking for a new cpu?
a 3700+ to a 3800+ isnt a great step forward - in some cases it could even be a step back - depending on how much use the particular applications you use make use of the second core!
Maybe its just me - but I dont see the point in that particular "upgrade".....
What is it that you do that you feel the need for something better? Maybe dual core would be a big difference for your particular usage?!?!
Or do you just have an uncontrollable desire to spend some money? ;)
