my nmap scan
18 Oct 2002
London
I was doing a scan from the office to my router at home.
Warning: OS detection will be MUCH less reliable because we did not find at least 1 open and 1 closed TCP port
Interesting ports on ##############(########):
Not shown: 1678 filtered ports
PORT STATE SERVICE VERSION
5190/tcp open aol?
6881/tcp open bittorent-tracker?
BT is ok, as I opened that one...
But what on earth is that other one? I haven't opened that. I don't even have any AOL products installed.
upnp is disabled on the router too.
Any ideas?
Nope no AIM.
I tried the netstat, and nothing is using port 5190. I tried nmap again, and it's still there too.
This is all very strange :/
I'm using it like this:
nmap -A -T4 -P0 ###########
Quick google shows that said virus could open the port... good call!
Trouble is, I have NOD32 installed :/
I also have a windows 2003 server box too, for the record. Should I install NOD32 on there? Seems an unlikely place to get a virus, but I suppose I'll try it later..
KingAdora said:
Nope no AIM.
Dont forget that if you have a session going through the router then you might actually be seeing the port of the outgoing session. Like I said try rescanning later, also it might be worth running nessus against that port and see if it can figure out exactly whats running on that port.
Thanks for the tip, I'll try later. I'll also try rebooting the router tonight and trying again tomorrow.
Not sure what you meant by this:
"Maybe you came across an open session as the port is greater than 1024"
Do ports below 1024 close quicker or something?
Sorry bit of a noob on this... :)
They are service ports wheras the ports above 1024 are client ports, service ports provide a service i.e internet website, FTP connection, Newsgroups..... wheras client ports are something you use to connect to that service i.e a port above 1024 would be used to connect to a website that runs on port 80
