my note is rooted. if i factory reset will it kick the root out?
Brick it, no. Reset may remove the SU app, but the root will more than likely persist. If you want a stock phone flash a standard firmware and reset the bootloader firmware counter, it may be showing a non stock count.
Best way of doing this would be to use ODIN to flash a stock firmware and use Triangle Away to reset the flash counter as mentioned above.
