Snigger.
Anyway, I need to replace the drop links on my Focus...it's been making a bit of a creaking noise lately when braking and turning to the left. Apparently worn drops links are the cause and cheap and easy to replace. So I bought a new set off the popular auction site and, happy in the knowledge that it was less than an hour's job, decided to have a crack at replacing them myself on Sunday.
One hour after starting on the passenger side and I simply could not get the old drop link off...the nut holding it is jammed tight. I tried copious amounts of WD40, leverage and swearing, all to no avail before finally giving up after one side of the nut looked it it was starting to round off.
Whats the best method for shifting stiff nuts? My dad has an oxyacetalene torch at work so I might take it up there at the weekend as I hear heating the nuts (fnaar!) can cause them to loosen. Is there a technique to this? Or do you jsut heat the nut for a while then have another go with the spanner?
Any tips from you spanner monkeys would be appreciated
but they still should be able to get it under there.
