Well i have as many a 4ghz bundle on the ud5 the problem seems to be getting my memory to run at the correct speed,here is what cpuz reports-
dram freq= 573.0mhz
fsb ratio=2:6
timings of 9,9,9,28,64,2T
The ram is reported as part number CM3X2G1600C9, so it is definatly the ram advertised and capable of 1600mhz!
I havnt personally overclocked since q6600 and dont want to have to learn i7 hence buying the bundle! If you keepers of the i7 wisdom can help i would be one happy guy!
dram freq= 573.0mhz
fsb ratio=2:6
