Hi signed up to OC a long time ago, but generally just buying things. had my !80 for awhile now, and thought id freshen it up a little. not planning on spending big money on it, so just a few cheap case mods.
started by stripping it
had a few holes cut, had a few quick read on the net and seeing how other P180 users did their cable management.
then i picked up a few things
new bracket to mount the 120 fan at the top where the 3 cd bays use to be
got the case all sprayed in black, wouldnt say paintwork is the best, but it will do
and this is the plan of my set up, need to buy longer screws to fit the fan at the back for the push pull config on the h60 rad
any suggestions or comments to make this better please
