Remove the drive from the old system and temporary install in you new system (but double check the boot order) then once in Windows format the drive.
is there not an easier way really don't think I can be chewed with thatReally???is there not an easier way really don't think I can be chewed with that
so using the above I just connect the old HDD then it will appear in My Computer then right click and format?
Thanks
yeah, once connected to your PC as a second drive just right click and go to format
Afternoon all, eventually got my new build up and running and ive moved everything off my old system on to the new one so I want to remove windows 7 from the old one and format the hard drive
If you are going to sell the drive on however, formatting does not fully erase the contents of the drive. For that you will need to use an erasing tool such as Eraser, DBAN or HDShredder.
A full format using a modern version of Windows will zero the drive.
