My Order Today - 04/03/2011
21 Feb 2011
Will be ordering later today from OC UK later today
Computer use , for photoshop CS5 & Photoshop Elements 9 & blu-ray + some light gaming
http://www.overclockers.co.uk/showproduct.php?prodid=FS-176-OE&groupid=43&catid=1444&subcat=
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System
Windows Pro 64
Asus GeForce GTX 460 1024MB DirectCU GDDR5 PCI-Express Graphics Card
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM
Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII Optical Drive - OEM Black
Akasa AK-274CB-4BLS 120mm Blue LED Fan X 2
I might go up to Corsair Vengeance 8GB ?
Thats a nice system however if you buy the components seperately you could probably squeeze an i7 2600k and 8GB RAM for the same price.
+1 to 8GB if your main use is CS5.
If you're looking to RAID the Harddrives or something, makes sense, but otherwise why have you got two 500gb HDD's, why not just one 1TB? Works out cheaper....
kd
order now arrive date tuesday :D , very happy with choice should last me awhile , then i will learn to build my own for next machine . . .
Nice system.
Which GPU did you choose?
Did you go for 8GB of ram?
I recently ordered an OcUK Primo Neo system for my parents, very happy with it.
Nice system.
I went for Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System
was going for 8GB but OC sales said i would loose the overclock :D
Nice system.
My first question was GPU (graphics processing unit) (graphics card) not CPU (central processing unit).
Shame about the 8GB. You should be ok unless you do a lot in photoshop
Is that the case even if you use these:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-295-CS&groupid=701&catid=8&subcat=1517
Same latency etc?
I'm thinking of buying the same system, but with 8gig ram.
What overclock would be possible with the above Ram?
I'm ordering tomorrow or Monday and need to know before I make up my mind.
Thanks.
Same latency etc?
Thanks.
Best to ask OC staff or make a post to ask the question , i am happy with Corsair Vengeance 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit , looking forward to my system :D
got my system today , bit disappointed its not clocked :mad::mad:
