My overclock isn't holding
26 Apr 2008
Bristol, Old Blighty
I've been running my E2160 at 3 to 3.2GHz for about a year. But the last few days, it's been having problems posting. It starts, stops, starts, stops, starts and then finally posts with my FSB set back to default.
Would this be a problem with my CPU or motherboard? The only hardware change I've made recently was swapping from DDR2 to DDR3 memory, could that be straining the memory controller too much? I've tried raising the VDimm with no success.
Try upping the NB volts a notch or 2. I used to have a P965-DS3P mobo which ran fine for months and then the OC would reset on some boots, upped the NB volts a notch or 2 fixed the problem.
