Hi all and thanks to those who read/reply to my post.
I've been lurking around the forums for some time and have read the stickies, only just bothered myself to make an account however!
I'm quite happy with my current overclock, temps under full-load are well within the acceptable range ( never higher than 72, using Corsair A70 ).
However, the way I have gone about my overclock is rather lazy (letting my asus p8p67 deluxe do most of the work with auto voltage settings) and in doing so I'm somewhat fearful of the CPU's lifespan.
I've basically got everything on auto, a x50 multiplier, PLL and similar settings set on high or extreme for more overclocking headroom and a fixed Vcore of 1.496 (even minor adjustments to this result in instability).
So my main concerns are:
Intel specifies much higher "safe" Vcore than I am reading on a lot of sites and forums, opinions on this?
Any guidance on how to manually lower some voltages (currently set to auto) would be greatly appreciated as my attempts just result in BSODs!
Also, even after reading the stickies, I am clueless how to overclock my crucial memory (16gb) (currently on 1333 [9 9 9 24] Command Rate 2T), again, any attempt results in BSOD
Thankyou for taking the time to read my post and extra thanks to those who may reply!
n3os3n signing out!
n3os3n signing out!
