I'm pretty happy so far...
OCZ GOLD 6GB (3X2GB) DDR3 PC3-12800C8 1600MHZ TRIPLE CHANNEL KIT
INTEL CORE I7 920 "D0 STEPPING" 2.66GHZ
ASUS P6T SE INTEL X58 MOTHERBOARD
Memory underclocked to 1520mhz, timings tightened to 7,7,7,20 from stock 8,8,8,24, 100% stable in memtest.
Baseclock @ 190mhz, 20x cpu multiplier, 3.8ghz from 2.6ghz, 1.225v
Temps look ok, stable in prime95 for i think an hour or so at the moment, slightly bumped some of the board voltages for a bit of extra stability. My only concerns are what should I be doing with the QPI and Uncore frequency?
Check the screeny for full info! any advice? is the NB frequency ok, seems a bit high... this is my first i7 so still a little apprehensive!
http://i181.photobucket.com/albums/x149/cogrady84/myoc.jpg
