my cheap as chips system is heading to 3.1ghz (stock 2.6)
spec:
amd athlon2 quad (stock cooler)
asrock k10n78 mobo (intergrated graphics)
2x2 gb kingston ddr2 (pc2-5300)
samsung 1tb harddrive etc etc..
windows 7 64 bit.
purpose for the machine is a mixture of business software - adobe suite, design/photoshop etc. some gaming and video. i tend to run several apps at once so the multi core i tought was a good idea.
im at the point i need to change the stock coolers, maybe the corsair h50 but probably go for quality air as im thinking itll be less maintainance over the next 5yrs. must be quite!
also a passive northbridge cooler maybe a zalman? or other?
question?
spec:
windows 7 64 bit.
question?
- is it worth buying some ram heatsinks or ram cooling at this stage?
- im aiming to overclock to 3.4 ghz (seems achievable)
- also looking to buy a budget graphics card, maybe a geforce 9800gt?
as this is the weak point in my system right now, the intergrated graphics just cant cut the mustard!
current sandra index is around 550 as i say the graphics performance is the weak point.
any comments on my build most welcome, bear in mind its a cheap system!
see http://valid.canardpc.com/show_oc.php?id=991999
