*** 14/03/2017 Added SMT off results***
Made the jump from 3770k to 1700 couple days ago. So far the gaming results are better than I expected, average framerate is generally just a few fps difference from my 3770k at 4.7Ghz. This is with my 1700 running at 3.9ghz ram at 2933 cl15. So basically the gaming performance remains the same but I also now have a huge multithreaded advantage.
R7 1700 3.9ghz 16Gb DDR4 2933 CL15
Gigabyte AB350 Gaming 3
GTX 1070 at 1947 core 4000 mem
3770K was running at 4.7Ghz with 16Gb DDR3 at 1866mhz CL10, Same GTX1070 of course.
Here are the game results that I tested, all at max possible settings at 1080p and 2x smaa/2x TXAA where applicable. I also included stock 1700 stock results for the games that I've benched. Hope this helps:
Heaven Benchmark:
3770K 4.7: min. 9.2 avg. 122.8 max: 270
1700 3.85 (forgot to rerun at 3.9): min. 32.6 avg. 121.7 max: 257.4
R7 1700 3.0 2133 cl15: avg. 115.8
Rise of the Tomb Raider:
3770K 4.7:
Mountain Peak 100.96 (min. 48.09 max 168.12)
Syria 68.82 (min. 26.42 max 99.84)
Geothermal 74.91 (min. 50.90 max 108.61)
Overall 82.32
1700 3.9:
Mountain Peak 101.32 (min. 49.11 max 172.23)
Syria 70.50 (min. 25.42 max 92)
Geothermal 71.32 (min. 41.37 max 99.17)
Overall 81.67
1700 3.9 SMT off:
Mountain Peak 102.67 (min. 38.07 max 144.98)
Syria 69.71 (min. 27.64 max 86.47)
Geothermal 72.05 (min. 35.61 max 93.35)
Overall 82.30
R7 1700 3.0 2133 cl15: Overall 69.49
Far Cry Primal:
3770K 4.7: min. 63 avg. 74 max: 81
1700 3.9 : min. 57 avg. 72 max: 83
1700 3.9 SMT off: min. 60 avg. 73 max: 84
R7 1700 3.0 2133 cl15: avg. 63
Rainbow Six Siege:
3770K 4.7: Overall min. 62.8 avg. 90.4 max: 139.9
1700 3.9 : Overall min. 63.6 avg. 91.3 max: 131.3
1700 3.9 SMT off: Overall min. 65.6 avg. 91.2 max: 128.1
Dirt Rally:
3770K 4.7: min. 71.98 avg. 94.66 max: 127.31
1700 3.9 : min. 72 avg. 93.89 max: 125.52
1700 3.9 SMT off: min. 71.94 avg. 93.39 max: 123.50
R7 1700 3.0 2133 cl15: avg. 92.81
As you can see from the above games, the average frames in these situations are within negligible level. So the conclusion is same as others have said really, that if you mostly play older titles that favours 4 cores or less, especially when you are running 144hz or higher refresh rate where the max fps really does count. Then the older gen i7 still have the raw power to really drive the fps. if you play newer titles at higher resolution when GPU matters more then you'll find the rysen, overclocked at least, will not dissapoint. But it has to be overclocked to really shine.
Sorry no 640x480 benches
***14/03/2017*** With a relatively modest GTX1070 it seems the SMT off performance increase in games is minimal at best, not really worth turning off SMT for. Bar the most powerful GPUs in SLI/Xfire configuration I doubt in most scenarios you will notice any difference.
Heaven Benchmark:
3770K 4.7:
Overall 82.32
1700 3.9:
Overall 81.67
1700 3.9 SMT off:
Overall 82.30
Far Cry Primal:
Rainbow Six Siege:
Dirt Rally:
All speculations of course.
