My p key is dodgy...
12 Sep 2003
Newcastle, UK
I've just bought a new keyboard and the p key is very hit and miss as to whether it works or not. Should I RMA or should I try and take it out and investigate? :(
give the keyboard a few GENTLE taps on the side to make sure there is nothing stuck under there preferably use air duster. if this fails then remove the key carefully if there is nothing under there then put key back the way it was then rma it
I remember when, in one summer job that I worked in, someone stole the 'p' key from a colleagues keyboard. Couldn't help, but laugh as she phoned IT to complain that "someone's taken the 'p'".
Lmao that funny ^^
I spilt coffee over mine the other day, don't suppose you have?Made the spacebar, B, V, and F keys go all funny, just took em off and cleaned with some flash kitchen cleaner, had to do it twice as they went funny again (1st time just used water)
