My pc build any suggestions or tips
2 Jan 2024
cov
My pc build
uk.************.com/list/ns6qwg
Any tips or improvements
Thinking off going down the liquid cooled cpu and gpu route not sure if I should use a tank or a water block as a reservoir
Wanted a 4k racing simulator and 4k gaming
Case
hyte.com/store/y70?v=163
nzxt.com/en-GB/product/h9-flow
Gpu block
ekwb.com/shop/ek-quantum-vector2-strix-tuf-rtx-4090-d-rgb-abp-set-nickel-plexi
Cpu block
ekwb.com/shop/ek-quantum-magnitude-d-rgb-1700-nickel-plexi
Water cooling kit
monitor
ASUS ROG STRIX Curved XG49VQ, 49 Inch DFHD
OR
Samsung Odyssey g9
Links not allowed it's against the forum rules.
List parts please.
Sorry didnt know they would be
AMD Ryzen 9 7950X3D 4.2 GHz 16-Core Processor
Asus ROG STRIX X670E-E GAMING WIFI ATX AM5 Motherboard
G.Skill Trident Z5 RGB 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory
Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Asus ROG STRIX GAMING OC GeForce RTX 4090 24 GB Video Card
Corsairs hydro x water cooking kit
gpu water block
EK Water Blocks EK-Quantum Vector² FE RTX 4090
Cpu water block
Ek water block velocity
Can you tell us more about this PC?
For example:
- What is your budget? (or is this a "money no object" vanity/hobby build?)
- Would you like to make savings if possible? If so, what is your ideal budget?
- Do you want liquid cooled, or is this just speculative?
For example:
Ok my budget was £3000 but its been pushed to £4000 the total budget is about £7000 that's pc and sim racing rig and monitor
I would like save where I can
First change is switching to ryzen 7 7800x3d
I would like it liquid cooled I've always wanted one and now you can customise a lot of the water cooling parts putting the 4090 into a ek waterblock and ek Waterblock on the cpu
