My PC is causing Power cuts.
23 Dec 2009
Hi,
Since yesterday afternoon my house has had 4 power cuts while my Desktop has been on. This has very occurred before. I can't completely assure that it is my PC but im 95% sure it is due to my PC.
If it is my PC, is this a warning sign my PSU is about to go?
So your RCD device has tripped cutting the power? Were the cuts immediate after starting the PC or at just a random point?
When my RCD kept tripping I traced it to some water in a trailing extension. As soon as I switched on a reasonably heavy load, such as kettle, PC, toaster etc it would trip. Isolate everything and try each socket in turn with a heavy load, maybe you'll be able to find the fault.
