- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
I wanted to talk about the PC case and the cooler I have, I'm am very impressed with the results of the CPU and GPU temperatures. I have an Antec Performance 1 FT case. Inside I'm running a AMD 7800X3D with a RTX4090, and 32GB 6000mhz CL36 RAM.
The CPU cooler is an Antec Vortex 360mm.
Vortex Radiator fans = 600RPM
Case fans = 560 RPM
So the PC is silent.
3 x 140mmx30mm front case fans (the storm fans included with the Performance 1 case - and 1 rear 120mmx30mm fan also included in the case.
My temps are stable at around 60 degrees on the CPU. It did peak at 71 for a second when the software first loaded, but that was a small 1 second startup spike. I'm just blown away by the cooling power of the case and AIO cooler.
When I run modern high end games the CPU temp is about 55 and my GPU temp is around 65 (Palit RTX4090)
I have been running prime95 for aprox 1hr now and here are the results of the temps.
Added some photos of the PC. as requsted
Case fans = 560 RPM
