ok, transferring my components out of my old case to a nice new one, i now can't get the PC to start
Damn job has taken hours..
Basically, i can see the motherboard light is on when i turn the PSU on, but when i go to start the PC nothing happens except a very brief flicker of light from the from case LED which lasts about 0.5 seconds. Note that if i try to turn it on again i don't get the flicker of light but if i turn the PSU off, wait for the motherboard LED light to go off, then turn the PSU back on and attempt to start PC again, i do get the flicker of light.
I'm thinking the problem is either the PSU (but haven't seen any sign of it being frazzled), the mobo (really hope not), or i have got the jumper pin things the wrong way round (which i don't think i have). I could be wrong though, i don't mess about with PC components often.
Any suggestions?
Thanks a lot.
Damn job has taken hours..Basically, i can see the motherboard light is on when i turn the PSU on, but when i go to start the PC nothing happens except a very brief flicker of light from the from case LED which lasts about 0.5 seconds. Note that if i try to turn it on again i don't get the flicker of light but if i turn the PSU off, wait for the motherboard LED light to go off, then turn the PSU back on and attempt to start PC again, i do get the flicker of light.
Any suggestions?
Thanks a lot.
