My PC keeps on freezing! help
30 Oct 2014
Hello
Recently I updated my Mobo / CPU / Rams after a fatal failure with my older PC.
So I did fresh Install of Windows 8,1 which I then upgraded to Windows 10 ( Completely fresh install with every single file being removed from the SSD Drive )
When I finished installing Windows 10 and PC restarted then Windows Automatically did Memory/Ram Check ( Not sure the name - Windows memory diagnostic tool )
and it passed which doesn't surprise me because the Rams are new
Then first thing I did is Download Google Chrome, GPU Drivers and AdBlock :D
Then I started Copying World of Warcraft ( Game ) from my USB Stick to my Computer and while it was copying my PC Frooze but I could still see that the USB is still working/doing something because of the LED Light that it has.
So my PC was "Frozen" and I tried to wait for Windows Error message or something but I didnt get any Error message so I had to restart my PC and everything was fine again but I still keep on getting these Freezes sometimes after 5 mins sometimes after 20min ( 20 Min is the Max )
Any ideas what is wrong?
Update: I tried sfc /scannow ( update 2 - Tried this Command as well DISM /Online /Cleanup-Image /RestoreHealth ) and it did found some corrupted files which should be now repaired but I still get these "freezes"
CPU - FX 9590
Mobo - Asus crosshair V formula Z
GPU - r9 290x
Ram - Team Vulcan 2133mhz 2x8gb
PSU- Corsair 750w
SSD - Crucial 250gb
Try reinstalling the windows 10 drivers first for the motherboard, then move onto resteating you ram. remove the GPU and try again, failing this reinstall windows onto another HDD
Maybe dodgy sata cable?
Just went to cpu support page and it needs 1403 bios for that cpu also it states requires special thermals cos of high tdp. Dunno what u have but might not hurt to check and maybe flash the latest bios to be safe.
BIOS Updated to the Latest Version ( Already was since I bought the Mobo )
CPU is being WaterCooled
Update: Tried MemTest86 everything fine
Prime95 5 hours everything Fine
Ran 3x different GPU benchmarks and Heavy loads everything fine
Any ideas WTF is wrong?
Im really getting ****ed and I believe OcUk sold me again faulty items
