my pc wont display anything on my monitor?? help
4 Jul 2009
Kilham, East Yorks
hi,i just slightly over clocked my cpu but now it wont display anything on my screen??.i think it could be my crappy psu because the pc is running fine just not displaying anything or could it be my gpu?.thanks
sorry just noticed i put it in the wrong section could a mod please move it?
Try to reset your CMOS. Do that by moving the little jumper on your board to a second position, then back to the original. If that doesn't clear it, you may have fried something in your PC.
and a little jump is?,sorry just never had too do anything before,but i thinks its my psu because my mobo is beeping every few secs its on
If you are unsure what the jumper is then just remove the battery on your board for a minute then replace it again this should reset the CMOS and undo your overclock.
It may be beeping as you may of overclocked the ram to much, I done this in the past, you will need to double check the ram speed when overclocking.
If you have the manual for the board it should show you jumper positions and give you a list of beep codes and tell you what they mean. but as RJC said - memory is probably a good place to start. resetting the BIOS should remove the overclock. if you still get the problem after doing this it might be worth trying 1 memory stick at a time and see what you get.
i did put the ram to 800mhz,and i only have the cpu and mobo manual if i can find them,thanks guys
how many beeps are there when you turn the computer on?
the beeps may give you an indication to the cause of the problem.
its ok now,i just took the battery out and booted it up and selected default settings and its working fine,thanks guys i owe you
