- 27 Oct 2013
OK, Ive had this problem for a few months now and its got me baffled...
If I fully shut the PC down, the vast majority of the time it will not open up, no post, nothing, the monitor will burst in to life as soon as the power on signal is detected, but within seconds it goes back into sleep mode (its connected via DP)
Occasionally it will open up as normal and run as thought theres no problem
Also, sometimes, when I turn on the PC, nothing whatsoever happens, but then a minute or 2 later, it will suddenly spring into life.
I now put the PC to sleep, or leave it switched on and I don't get the problem.
Anyone know what the problem could be??
