My PC343B [95% complete]
2 Aug 2004
Buckinghamshire
Hi all,
This build has been a long time in progress, here's a list of features:
  • Dual DDC Pumps (EK Dual top) for increase in head pressure and redundancy
  • Custom braided HX1000
  • Custom NB block top, designed to fit the DD MCP NB base - allows hardmount on my DFI board
  • Custom painted Thermochill radiators, with rivnuts
  • Everything apart from CPU block base is nickle plated - southbridge sink and PWM sinks are hardmounted
  • EK 8800GTX top, thinned and screws are recessed - making it single slot
  • Custom cut radiator grill on the top of the case
There's still the following to do:
  • Get custom feet lathed
  • Attach 3 fans to the back of the case, have fans just need more MDPC-X Braid
  • Get G/14 extenders for the EK Multioption res (tissue under PSU as the BP compressions don't make full seal)
  • Re-heatshrink the front IO cables with glued lined heatshrink
  • Clean up the remaining wires, especially around the HDD/Optical drive area
Mmmm lovely case and really makes it neat inside having the extra room to hide stuff out of the way, great build
Will look forward to the other 5% getting completed
/subscribed
That's really smart! You know the bolts/screws you've used on the roof to hold the fans in, are they nuts and bolts or proper fan screws with allen heads?
I want some. :P
They're just M3 machine screws - the reason I can use the M3 scrws without bolts is due to the Rivnuts I've installed in the radiator mounting holes.
