Hi All
I'm thinking of purchasing the following setup:
OS: Vista Ultimate 64 bit
MOBO: Gigabyte GA_P35_DQ6 (Socket 775) PCI-Express DDR2 Motherboard
MEMORY: PC2-9200 1150MHz Reaper HPC Edition Dual Channel DDR2 (OCZ2RPR11502GK)
COOLER: Zalman CNPS9700-LED Aero Flower (Socket AM2/939/754/775) CPU Cooler
CASE: Antect P182
CPU: Intel Core 2 Duo E6600
VIDEO: BFG GeForce 8800 GTX OC 768MB GDDR3
PSU: Enermax Infiniti 720W EIN720AWT ATX2.2 Modular SLI Compliant PSU
Ideally I'd like to get this system up to 3.45ghz with an FSB of 575mhz (x6) . That should be achievable on a 1:1 with the reaper memory but is my FSB ambition to high?
Would you recommend changing any of components? Should I be striving for a higher FSB? I'm hoping that reaper memory should do up to 700mhz
I really wanted to get one ATI Radeon HD 2900 XT and then add another later when I needed it (this board supports Crossfire) but it seems like the 2900 XT is a dud. Should I still go with ATi and hope that driver updates fix the performance? I know the one 2900 XT won't compete with a GeForce GTX 8800 but 2 in Crossfire should beat it. I'm a bit worried about the heat the 2900 XTs seem to generate.
CASE: Antect P182
. However, you probably misinterpreted what I wrote...I meant the memory should be able to handle 575mhz (1150) no problem but will the FSB go as high as 575? (providing the CPU can handle 3.45 but let's just assume it can for the moment )
You can't even buy them..But it looks as though the 120 Extreme is now available
