Hello,
I installed some RAM in my system today, and a new graphics card, HD 5770. I first installed the RAM, tested the PC and it seemed fine. I then took out my old video card, and installed the new one. I then turned on my PC, and it booted up okay. The resolution though was low, and so the computer hadn't seemed to have detected the graphics card. After about a minute after logging on the computer froze - it seemed to do this after making the hardware detected noise. It didn't freeze up in safe mode, but I guess this is because in safe mode the graphics card wouldn't be detected.
I shouldn't have done this as it was unnecessary, but I decided to take out my old RAM, and left the new in there, just to make sure that the problem didn't lay with RAM - in hindsight it seems clear that there wasn't a problem with the RAM. I connected my PC back up, and it made a pop sound, but the motherboard continued to boot. I could then smell a little bit of smoke, and immediately pressed the off switch at the back of the PC. I'm a bit afraid to do anything now. My power supply is a corsair 520W one.
What should I do now? Did I overload the power supply? But if I did then why did it work okay before I removed some RAM?
Thank you in advance.
but I don't see what could have caused it. I smelt the power connector to the card, and it seemed to smell a little smokey (again, I could be wrong). All I did was take out my old card (7900 GS) and fit the new card in the same slot, and connected the power connector to the card - the same connector that was used on the old card. I used this cable,
- it looks like it uses a red wire for a second 0V... well spotted!
