Hey,
I have touched this subject before but my Cpu temps concern me, Espically if am wanting to clock it later down the line.
At idle my temps are between 52-57 on all four cores although am using Arctic 7 and that pushes air to my 2 rear 80mm sharkoon exsurst fans.
I was using a Fan Zalman fan control on my CPU fan but this didnt improve the temps much only to high 40's.
If i take off Q-fan control in the MoBo set up the temps will lower to about 40 at idel....But the NOISE (@ 3100rpm !)
I cant imagin what is wrong as i know people with a temp of 57 on load with 3.0ghz overclocked (same cpu)
Any Advice?
i have Checked and Double checked everything is fitted correct and fans blowing the right way.
Any Advice?
