Hi,
This is my first real attempt at overclocking, done a little in the past, mainly on my VGA cards but that is relatively easier compared to CPU and Memory.
Basically I am a n00b at overclocking, so if I use any term incorrectly, please put me right as I do want to learn!!!
After reading the many many posts on this website, I made the following changes in the BIOS:
Multiplier = 8x
FSB = 400 which gives me 1600
Vcore = 1.4250V
Memory FSB = 860
The CPU clock speed is now at 3200Mhz and the memory at 860Mhz
My idle temps are ~41C - (the cores are between 43 - 48 each varying temps).
I have ran Prime95 for 30 minutes and everything is okay (I will do an 8 hour test evenutally), see below:
During the tests the cpu core temps climbed upto 70C, but these did fluctuate between 60C - 70C. Once the test finished the temperatures dropped very quickly to the idle temps (Tuniq tower fan is set to 1500rpm).
One thing I did notice was the VCORE voltage kept changing, at idle it is (as per CPU-Z) 1.392 (I set 1.425 in the BIOS), during load it changed:
1.392 -> 1.376 -> 1.368 -> 1.360 -> 1.352 <-> 1.360
Is this voltage change normal? Is it VDrop or VDroop? if not what can be done to stop this drop in voltages?
My next query is about the memory speed and timings, I really am stuck with this, in the screenshot you can see the current settings, what are the "ideal" settings? I have increased the FSB and think they will go further but am also interested in the timing side too.
Thanks in advance for any advice/help.
Multiplier = 8x
Vcore = 1.4250V
Memory FSB = 860
