Is the thermal material properly applied?
using the default thermal pad/gunk won't raise temps 60c ROFL
man ppl make way too big a deal over TIM, you can use toothpaste and get decent temps if you're mounted properly.
i'd say 99% OP hasn't got the stock cooler mounted properly, sometimes those pins look in place on a quick glance but they actually aren't.
