my quest for 4ghz help needed
31 May 2009
HI all i would like to reach 4ghz stable on the following system
gigabyte ga ep45-ds3p
Core 2 Duo E8400 Socket 775 (3.0GHz) 1333FSB 6MB L2 Cache
Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel
gaindward gtx260
CoolerMaster Elite 333 Black Case
Corsair 650W TX Series PSU
i have used templates of this site and can boot into windows and do stuff but orthos stoppes after 2 mins here is how i have my settings in bios
Robust Graphics Booster ...............: [Auto]
CPU Clock Ratio .......................: [ 9]
Fine CPU Clock Ratio...................: +0.0
CPU Frequency .........................: 4GHz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 400Mhz
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive........................: 800mV
PCI Express Clock Drive................: 900mV
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................: [STANDARD]
Extreme Memory Profile (X.M.P.)........: [Disabled]
(G)MCH Frequency Latch.................: Auto
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ................: 801
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
tRRD...................................: auto
tWTR...................................: auto
tWR....................................: auto
tRFC...................................: auto
tRTP...................................: auto
Command Rate (CMD) ....................: auto
Driving Strength Profiles
Driving Strength ......................: [Auto]
Channel A
Static tRead Value.....................: 7--10
tRD Phase0 Adjustment..................: [Auto]
tRD Phase1 Adjustment..................: [Auto]
tRD Phase2 Adjustment .................: [Auto]
tRD Phase3 Adjustment..................: [Auto]
Trd2rd(Different Rank).................: [Auto]
Twr2wr(Different Rank).................: [Auto]
Twr2rd(Different Rank).................: [Auto]
Trd2wr(Same/Diff Rank).................: [Auto]
Dimm1 Clock Skew Control...............: [Auto]
Dimm2 Clock Skew Control...............: [Auto]
DDR Write Training.....................: [Auto]
Channel B
Static tRead Value.....................: 7---10
Motherboard Voltage Control
Voltage Type...........................: [Manual]
CPU---------------------Normal-----------Current
Load Line Calibration..................: [Disabled]
CPU Vcore...............1.30000V.......: 1.42500V--showing 1.392v in cpu-z
CPU Termination.........1.200V.........: 1.200V
CPU PLL.................1.500V.........: 1.500V
CPU Reference...........0.760V.........: [Auto]
MCH/ICH
MCH Core................1.100V.........: 1.3200v
MCH Reference...........0.760V.........: [Auto]
MCH/DRAM Reference......0.900V.........: [Auto]
ICH I/O.................1.500V.........: 1.500V
ICH Core................1.100V.........: 1.100V
DRAM
DRAM Voltage............1.800V.........: 2.100V
DRAM Termination........0.900V.........: [Auto]
Channel A Reference.....0.900V.........: [Auto]
Channel B Reference.....0.900V.........: [Auto]
Advanced Settings
Limit CPUID Max. to 3..................: [Disabled]
No-Execute Memory Protect..............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support...................: [Disabled]
x C4/C4E State Support.................: [Disabled]
CPU Thermal Monitor 2(TM2) ............: [Enabled]
CPU EIST Function......................: [Disabled]
Virtualization Technology..............: [Enabled]
Integrated Peripherals
Legacy USB Storage Detect .............: [Disabled]
can any one suggest how i can get stable thanks
- Power supply : Vdd: 1.8V ± 0.1V, Vddq: 1.8V ± 0.1V
- Double-data-rate architecture; two data transfers per clock cycle
- Bidirectional data strobe(DQS)
- Differential clock inputs(CK and CK)
- DLL aligns DQ and DQS transition with CK transition
- Programmable Read latency 5 (clock)
- Burst Length: 4, 8 (Interleave/nibble sequential)
- Programmable Burst type (sequential & interleave)
- Timing Reference: 5-5-5-18 at +1.8V / 5-5-5-15 at +2.2V
- Edge aligned data output, center aligned data input
- Auto & Self refresh, 7.8us refresh interval (8K/64ms refresh)
- Serial presence detect with EEPROM
- High Performance Heat Spreader
- PCB : Height 1.180” (30.00mm), double sided compone
