My Quest for a cooler xbox360
17 Aug 2004
Ok call me crazy but i just got sick of seeing all that crap covering those twin deltas so i decided to let them breathe a bit and do a bit of case modding
Here are the results
Since cutting the grills the airflow has increased greatly and the air coming out is no where near as warm before the mod
Looks a bit gash for now but i do plan on cleaning it up at a later date, lets just call this a beta
TheMagicPirate said:
There goes your warrenty. lol.
Will that actually improve anything though?
Yeah i thought that
You are utterly mad if you ask me but hey its your kit. You will never ever be able to sell it in the future
Christ, ever heard of resizing a pic after youve taken it off your camera? :eek:
From past experience of doing a similar thing with PC's, I came to the conclusion that it makes minimal difference with regards temperature. The only thing that might change is the fan noise being slightly quieter.
da_mic_1530 said:
you have guts man, i think you should take some data from this experiment, im sure a lot of people would be intrested in this mini project
Good idea actually
Ill borrow a laser thermo from work next week and compare a stock box with my modded at the point of exit, im starting to think now the air is not actually cooler but there is just more of it giving me a false impression.
Even so the more that comes out i figure the more that goes in, which makes me think larger inlets :P
Phat Momma Hoe said:
Just out of curiosity, how did you manage to attack that without getting any little bits of shell / metal inside ? Asuming you didnt totally dismantle it that is
Sidecutters with a gentle twisting action.
And sorry about the pic size, i figured the thumb would be enough and if peeps wanted to see all its glory they would be preped for the d/l
james.miller said:
judging the failure rate of these atm, that is an utterly moronic thing to do.
still, good job good job:D
My xbox 360 sits onto of my sky+ box and not had one problem with it.Even looking on this very forum i have yet to see anyone who has sent their xbox 360 back. :D
Havent really noticed the decrease in noise yet, seems the dvd drive constantly spinning will pretty much kill any idea of that
If it dies atleast ill get a hands on look at whats inside
Then ill go and buy another and leave it alone ! and i bet i still wont have a hard drive by then!!!!!
Sorry but this is simply moronic, if your going to invalidate your 360's warranty you might as well do something worthwhile to it, the least you could have done is remove the metal inner grill and keep the plastic one.
His xbox 360 so who are we to judge. ;)
