Come on L1J how's the Golf going? I'm flying along here
Slowly but surely!
Some of us are busy ripping things off and havent got time to post on the internet
Nice progress, keep it up
Slowly but surely!
You are right when you say the lighting loom on 205's are useless...
Even the rear lights are only getting 10v or so, so this is next on the to fix list..
Is the clutch actually on the splines or sat on the end of the shaft?My gearbox is miles off sitting on the dowels, about a half inch before the faces go flush and the dowels stick out by about a quarter inch. Going to have to remove and try and refit it myself in the week, but its going to be cold and dark and crappy![]()
also be aware that the std lever and its mounting point may well fall apart as there not designed for the abuse youll give them using a set up like that,
Nope you don't, cable handbrake is being retained too.and also youll have problems when it comes to mot time for the car as i helive if your on a hydralic handbrake you need a twin line system to pass......
One really big question here.... are you going to rally this car??? if so do you know what class its going to run.... and do you have a copy of the regs / blue book to work to? as a few minor changes from original spec can make a huge difference to the class
