In the first pic, is that an adult standing next to the case, it looks like it's over waist-height!!![]()
Wonder what the temps are like? and if it is noisy as it looks?
zia
.Bold move for the manufacturer to do a case with a very different layout like this, I do like the way how they have implemented good air cooling into a normal sized case, I sure would not have thought of this, I would expect it to be a good cooled case with heat rising, but if only they made some kind of a cover even if it was just for the wires on the top to keep it neater, but if its underneath a desk then it doesn't matter, besides my observations of the case itself, good clean looking build mate wohoo.
looks nice, how is the v-shaped light on the top of the case powered ? that's the only thing i don't like about this case.
thanks.
But how did you get a hold of one?
The 01 only had 2 of the 180mm fans at the bottom but it was still cool and much quiter than my 690 was, even though I upped my CPU fans to 1900rpm's.
Temps were also slightly cooler (before i changed fans).
Case being more quiet as CM 690 isn't hard because of CM being so leaky.The 01 only had 2 of the 180mm fans at the bottom but it was still cool and much quiter than my 690 was, even though I upped my CPU fans to 1900rpm's.
And overal design of these Ravens is at least semi-quiet... but blowing it all out from roof just means noise of exhaust being directed lot more towards user.
But if you consider 1900rpm aircraft in takeoff as quiet in anykind computer (not special noise insulation) case then you're as qualified to call something quiet as colour blind to judge paintings.
