- 4 Mar 2009
Objectives: To build an air cooled ivy bridge machine capable of running modern games at full 1080p resolution with all the eye-candy turned up, whilst being whisper quiet at the same time. Machine should also be fully silent in general use i.e. web browsing, youtube, minesweeper, etc.
Budget: Not a huge concern, but I like to keep it sensible. I see no value in spending extreme amounts on extreme components, if mid range parts would suit my needs just fine. Then again, I will always go for quality parts from reputable manufacturers since downtime = pretty bad.
Methodology: Since this isn't a new build, I will be adding & removing parts as and when my budget and needs allow me to do so.
So lets get started. Below is my machine as it currently stands.
And now for the interior.
I know, I should have given it a quick wipe before taking these pics. Also no proper graphics card in there yet, as i've sold the ATI 6850 that was in there before in anticipation of getting a new card soon. More on that later.
I've done a few mods to the case & desk to help reduce some of the noise being generated by the hard drive.
This stuff is real good. It's called luxury liner pro, a sound deadening material typically used on car body panels for deadening road noise. I had some left over and thought i'd put it to good use.
It's fairly thick and does weight a fair bit. In this case (no pun intended) it was needed because the side panel of the Lian Li P50 is 100% aluminium, which tends to vibrate pretty easily. If you are wondering, the hard drives are clamped onto hard drive trays, which slide into the chassis using rubber grommets.
Another source of vibration noise is the case feet. I can't stress enough how much of a difference this stuff has made. It's practically removed all vibration induced noise from reaching my ears.
I have all my fans hooked up to a zalman fan contoller. They all run at minimum and provide good cooling, but i've placed inline noctua u.l.n.a.'s on some of the noisier fans to make them spin a bit slower.
Current spec:
Motherboard: Gigabyte EP45-UD3
CPU: Intel Core 2 Duo E8500
RAM: Geil 4GB DDR2 800Mhz
Graphics Card: Sapphire Hd 5450 (Silent)
CPU Cooler: Noctua NH-U12P
Fans: x2 Noctua NF-P12, x2 Noctua NF-S12, x2 Lian Li 140mm
Hard Drive (1): Samsung 830 SSD 256GB
Hard Drive (2): Samsung Spinpoint F1 7200RPM 1TB
Optical Drive: Samsung DVD-RW
Power Supply: Corsair HX-520w Modular PSU
Case: Lian Li PC-P50B
Proposed Upgrades:
Motherboard: Gigabyte Z77X-D3H
CPU: Intel Core i5 3570k
RAM: Corsair XMS3 8GB
Graphics Card: Asus GTX 660TI Direct CU II
I've chosen this motherboard mainly because it supports SLI, which will allow me to add another 660TI in the future when I need the extra graphical performance. Multiple reviews have shown that Keplar scales extremely well in SLI, often by as much as 90-95%
I've chosen this particular graphics card for its high performance, low noise, and excellent power consumption.
So that's all I have planned so far, until I get paid next week. I'd love to hear any comments or suggestions from you guys & girls.
EDIT: Also need a CPU cooler, but can't decide whether to get the Noctua D14, Corsair H60/H80 or something a bit cheaper. Will be overclocking to around 4.2-4.4 Ghz. Any ideas?
Current spec:
Proposed Upgrades:
