- 17 Aug 2003
- Woburn Sand Dunes
Ok I've kept a few people waiting for this, i apologise lol but finally here it is. My review of cowan's latest effort, the 4gb cowan D2
The Specs
* MP3, OGG, WMA, FLAC, WAV, APE* , Moving Picture Playback, FM Radio Receiver and Recording, Voice Recording, Line-In Recording, USB Storage
* TXT (Text), JPEG (Image) File Viewer (Image Enlargement, Background Screen Designation)
* Built-in Flash Memory (2G/4G)
* USB 2.0 Interface
* 2.5 inch 16 million color 24bit TFT-LCD - QVGA (320x240) Touch Screen support.
* Long Playback Time : Music Up to 52 hours, Movie Up to 10hours continuous playback
(Based on company's self-test, the Music playing time may be shortened according to LCD backlight usages.)
* Multi language support
* Enhanced Integrated Navigator
* Play/Pause, Recording/Pause Next Song/Previous Song, Fast Forward/Rewind, Section Repeat Resume, Fade In, Auto Play Features Search Speed, Skip Speed Setup
* Various EQ and Sound Field Effects
- User-Adjustable 5-Band EQ
- Normal, Rock, Pop, Jazz, Classic, Vocal, User
- Supports BBE, Mach3Bass, MP Enhance, 3D Surround and Stereo Enhance
* Clock, Alarm, Pre-Scheduled Recording, Sleep Function, Power Saving Shut down.
* LCD Auto Off Time Adjustment, Brightness Adjustments
* Easy Firmware Upgrade
* Supports ID3V2, ID3V1, FileName
* Product Info. Display (Firmware version, Memory Capacity/Usage)
* Supports MAC OS (Data transfer only), Supports Linux v 2.2 or higher (Data transfer only)
Software
* JetShell (File transfer, MP3/WMA/WAV/AUDIO CD PLAY)
* JetAudio VX (Integrated multimedia player software, music/video conversion feature)
Playback Format
* MP3 : MPEG 1/2/2.5 Layer 3, ~320kbps, ~48khz, mono/stereo
* WMA : ~256kbps, ~48khz, mono/stereo
* OGG : ~Q10, ~44.1khz, mono/stereo
* FLAC : Compression Level 0 ~ 8, ~44.1khz, mono/stereo
* WAV : ~48khz, 16bit, mono/stereo
* APE* : TBD
* Video File up to 320x240(QVGA), 30fps
* JPG, TXT
Folder Limit
* 500 folders and 5,000 files
RADIO support
* FM RADIO : 76Mhz ~ 108Mhz, 87.5Mhz ~ 108Mhz
* WMA : 32~256kbps recording support
Display
* 2.5 inch 16 million color(24bit) TFT-LCD : QVGA (320x240) Touch Screen support.
Built-in memory
* 2GB, 4GB
External Memory
* (SD, MMC) Card Slot
PC interface
o USB 2.0 High Speed
File transfer speed
o Max. 35Mbps (Upload 40Mbps)
Power
o Built-in Rechargeable Lithium Polymer Battery
Playback time **
o Music : Max. 52 Hours Continuous Playback
o Movie : Max. 10 Hours Continuous Playback
o Charge time - About 3.5 hours by adapter, About 7 hours by USB
o SNR - 95dB (A-Weighted)
o Frequency Range - 20Hz~20KHz
o Max Output - 16 Ohm earphone : 37mW + 37mW
o Size - 78.0 X 55.4 X 16.6 mm (W x H x D)
o Weight - 91g (Include Lithium Polymer battery)
* APE will be supported by future firmware upgrade.
** Playback time is based on company's self-test, The music playing time may be shortened according to LCD backlight usages.
Some impressive specs, notable the power output (37mw) and the their claim of a 52 hour battery life. not only that but it has a touch screen the same size as a video ipod's (more on that in a bit) Impressive set of features for a unit so small.
