my rig idear
17 Feb 2011
my budget is 800 the parts in the list are all the parts i need but is there any thing i should change am open to ideas
kind regards thanks for looking and any advice
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail
Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard
£173.99
Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD
Noctua NH-D14 Dual Radiator CPU Cooler (Socket LGA1366/LGA1156/LGA1155/LGA775/AM2/AM2)
£72.98
Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit (MV-3V4G3D/US) x 2
(£89.98)
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin x2
£31.96
Arctic Silver 5 Thermal Compound (3.5g
Total :
£757.86
ah yes, there it is.
May I ask what you will be using the system for and what components do you already have that you will be using with it?
