My Rig
12 Jun 2007
Ireland
Rig:
Case: Enthoo Luxe
PSU: Evga 850g2
Cpu & Cooler : i7 4790k @ 4.5 ghz 1.168v in summer , 4.7 in winter (delided) Cooled with Kelvin S36
Motherboard :Z97 Evga Clasified
Memory : Dominator-GT 16 gig 2200 9~10~11~27
GPU: Evga 980ti Reference 1400/3800
SDD: Samsung 840 evo 120gig & 1Tb
Monitor: Dell S2716DG 2560x1440 144hz G sync
Headphones: Sennheiser HD 555 (moded to HD 595)
Keyboard: Razer BlackWidow Clasic
Mouse: Razer Deathadder 2013
Mousepad : Steelseries QCK+
I know need to change ram heatspreaders to black and get rid of that cd dvd rom when ever i have good broadband connection or need to buy portable one ;)
Looking good, mind you can't really get 'inside the motherboard :p'
But looking forward to the finished product :)
lookin good dude - just like my setup albiet different motherboard ;)
Not sure how noisy them apache's are - you using them for pulling in air or pushing air outta the back? I'd recommend using just one fan for pulling cold air in (the top fan will pull the heat straight outta the top of the case) - it'll yield better results with that setup. using two fans makes about 1Degrees C difference - not really worth the extra noise - Tested both push/pull with one and two fans in my antec 902 and found it much better to pull air in from the back.
hth.:)
God help you if it cocks it leg up, zapped PC, zapped Dog :eek:, just thought it could be a be a bitch lol.:o
The Apaches are silent good performing fan's, putting the H50 push/pull config inside the case depend's on your case airflow how good your temp's will be.
Don't forget if you mount the H50 outside, the rad will clog up with dust a lot quicker. There was a thread showing a H50 rad well clogged up after about two month's not to long ago.
If you do it might be worth putting a filter on the outside of the fan, it will be a lot easier to clean > Filter/fan/rad/case, plus it will prevent the inside of your case getting covered with dust as well.;)
Enjoy your new PC m8. :)
around 53~55 degrees on prime using cpuid and probe 2 , IC Diamond in few days should shave few degrees off
