hi all
i rmaed my gfx card 7900 gs 3 days ago and got it back today
inthe origianal email after i sent the card back it said
The product GX-042-OK on RMA RMA------ has been replaced, this will be sent on a new order with order number ------.
yet when i recieved my gfx card back in the letter inside the box it said this.
you have recently returnted products on the rma number shown above.the product is being returned to you for the following reason.
there was no fault found.please check your other hardware or software installation
other comments.
tested and the card works fine had it going through the benchmarks and no fault was found it was looping on the tests nothing faulty???
looping whats this mean how can i fix it?
so this is the reply i got but when i was rmaing the gfx card i did because i found out that when i was playing games lines + triangles were appearing all over the place
i also used ati tools and scanned for artifacts when i done this the box in where it shows for artifacts went all yellow straight away yet they say they havent fixed it and when i scan for artifacts now theres nothing turning up ???
what the hells going on lol any1 got any ideas please?
thx
other comments.
thx
